Any benefits from a large cap HEI?
Old Dec 23, 2011 | 11:26 PM
Awesome-X's Avatar
Car: 87 Camaro
I found an 84 Z28 parts car with a CCC 305 and it has a large cap HEI, while my car has a small cap HEI. Can I swap them out and if so will there be any benefits from the large cap? I also got the manual hatch motor out of it and was wondering if I could mount that in my 87 that has a non working electric hatch pull down?
Old Dec 23, 2011 | 11:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Any benefits from a large cap HEI?
Simplicity.
With the coil mounted in the cap, it simply needs a good voltage supply and an ignition feed.
Larger cap has wider spaces between the posts. Less chance of crossfire and increased timing accuracy.
Although there are millions of them in many vehicles, the coil in cap style isn't that great because of the heat that the coil gets. For everyday driving and street/strip use, it's perfectly fine. For all out performance, an external coil style is better.
You can't however change out your small cap HEI for a large cap HEI without doing a bunch of changes. The small cap HEI is completely controlled by a computer. The large cap HEI still has weights and springs inside and uses a vacuum pot to control part throttle timing advance. Although you could drop in the large cap HEI, it would become a simple mechanical system. I doubt a CC large cap can be controlled by the computer that's designed for a small cap.
If you're wanting to get rid of the computer, an old school large cap HEI is the easiest way to go.
Old Dec 24, 2011 | 12:40 AM
Awesome-X's Avatar
Car: 87 Camaro
What a shame, I want to keep my CCC. I figured that there would be some difference that would keep me from using it but that's fine there isn't anything wrong with my small one so why fix what isn't broken?
Would you happen to know anything about the hatch pull down thing?
Old Dec 24, 2011 | 07:52 AM
ex-x-fire's Avatar
Both the large & small cap ccc distributors can be swapped, the wiring is the same color. Thay make a conversion harness or you can make one, go to a junkyard & get the est harness from each type, then splice in the middle.
Old Dec 24, 2011 | 07:55 AM
ex-x-fire's Avatar
Here's a picture of one.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
corey8084
Sep 17, 2015 02:56 PM
TBRays98
Sep 6, 2015 05:05 PM
