Coolant leak (passengerside of block)
Old Dec 25, 2011 | 02:04 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Is it possible to replace a freeze plug while the engine is in the Camaro? Would JB Weld work to seal the leak?
Old Dec 25, 2011 | 08:56 PM
ex-x-fire's Avatar
Re: Coolant leak (passengerside of block)
Yes the freeze plugs on the side can be changed while in the car, might have to remove motor mount, starter,ect that might be in the way. It can be tough to do while lying on your back. I've used socket & extentions(so I can get a good hammer blow) to get the plugs in, don't try to patch the plug, it'll probably leak shortly afterwards.
Old Dec 25, 2011 | 09:00 PM
Found the problem. Looks like the bolt next to the 8th spark plug is leaking. Gonna pull those lower last 2 head bolts and torque in some new ones. Hopefully it'll seal the gasket better.
Old Jan 13, 2012 | 05:31 PM
55tpichevy's Avatar
Car: 55 chevy,2000 corvette
Engine: 1990TPI and LS1
Transmission: TH350 W/gear vendor and 6 speed man
Axle/Gears: 85 corvette 3.07 and 2000 vette3.07
I've had the same leak I've got 8k on new engine and have drained the system three times cleaned the hole with brake cleaner blowen it out with air dry and resealed with black rvt as recomended from builder. that bolt hole is 7 inches deep into water jackit . As I drained the antifreeze i have a pet **** to drain driver side of block drained it went to pull that bolt out, water came out at high pressure, so I pulled the knock sensor and drain that side of block to releave the pressure. anyway I hope you have luck sealing it . mine started leakinkg slowly now i'm going to try leak seal! Mike
Old Jan 13, 2012 | 05:37 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
on sealing head bolts, i prefure using permatex #2 on the threads.
Old Jan 13, 2012 | 05:41 PM
I decided what I wanted to do. I'm just gonna park the Camaro for about 2 months. Then when I get my income tax, I'm gonna buy me a new set of AFR 1054 heads along with a new set of headbolts. If I'm gonna repair the leak, I'm gonna do it the right way, with some added power. O' yeah!!!!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jorlain
Oct 8, 2015 01:57 AM
89 formula TPI
Oct 6, 2015 08:40 PM
Nick McCardle
Sep 10, 2015 08:36 PM
