rebuilding 1988 305
Old Jan 1, 2012 | 08:10 PM
trafficlightguy's Avatar
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
rebuilding 1988 305
Lets get this out of the way, put a 350 in it, Well I dont want to.
well first I sent crank out to get cleaned up and then reinstalled it with new main bearing and rod bearings
All new rings installed also
LT1 Cam and comp cam springs 5703, all intake and exhaust valves were cleaned of carbon, and reinstalled with all new valve seals and O rings
The orginal head swirls were ported
Started to reassemble the heads after a quick paint job of chevy orange on the heads and block
Next
Removed all the old freeze plugs and installed New
Next will be installing double roller timing chain, cam and lifters and rods, still looking for a set of 1.6 roller rockers self aligning
any comments or question will be appreciated
UPDATE sent my intake and oil pan out for powercoat at a friends pick them up today
also installed the heads, new rear main seal and timing chain cover
Old Jan 2, 2012 | 06:44 AM
ex-x-fire's Avatar
Re: rebuilding 1988 305
Yeah, don't use visegrips on the crankshaft.
Get one of these.
Old Jan 2, 2012 | 07:05 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
personally im glad chevy quit painting their engines orange.,
Old Jan 2, 2012 | 09:06 PM
ex-x-fire's Avatar
Yeah, they went from a bright color to black.
Black is really exciting
Old Jan 8, 2012 | 07:19 PM
Car: 1988 iroc
Engine: 350 30 over
Re: rebuilding 1988 305 update
well the weather in new york was nice for a few days so i got a lot done, but not on the camaro, I lifted my sons xterra 3"
But i did get the heads back on the camaro and did remove the fly wheel the bolts were a serious pain in the *** they had to be headed and chisled toremove rear main seal.
Now i need to get 1.6 roller rockers self aligning and water pump
Old Jan 9, 2012 | 05:36 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
yeah i noticed too
Old Jan 14, 2012 | 03:50 PM
Car: 1988 iroc
Engine: 350 30 over
well my new 1.6 rockers came today so they went on
did the adjustment installed the dist everything line up great
jhawkeye
May 25, 2022 06:33 PM
fbirdroller
Sep 2, 2015 10:27 PM
Keith5
Aug 27, 2015 04:37 PM
stalkier
Aug 21, 2015 01:54 AM
kyleb24
Aug 15, 2015 08:24 AM
