383 tpi will not start
Old Jan 2, 2012 | 04:05 PM
SCOTT OVERMANN's Avatar
I have a new 383 with a tpi that will not start.I have repl the fuel pump with an intank walbro for fuel injection.I had a starter issue with an intermittent problem with an armature.I have that issue fixed.I have repl the ignition switch.I do not show any fuel pressure at the fuel rail on my street and performance gauge.The engine will crank but not start.What do I check next?Do I go back to fuel pump and work my way forward to the fuel rail
thanks, Scott Overmann
Old Jan 2, 2012 | 04:31 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 383 tpi will not start
So work out why your pump is not pressurizing the rail.
Can you hear pump actually running?
Old Jan 2, 2012 | 06:16 PM
yes I do for 2-3 secs
Old Jan 2, 2012 | 07:24 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Put 12v to terminal G on the ALDL connector. Pump will run full time.
Check pressure.
If no pressure showing , clamp return line.
If pressure comes up ;fuel reg faulty.
If not then filter blocked or fuel not leaving tank.
The connecting hose from pump in tank could have come off so no flow out of tank
Caspar
Jun 19, 2016 11:19 PM
Wade787b
Sep 29, 2015 01:15 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
