Wow, water pump swap was way easier than I thought
Old Jan 5, 2012 | 10:01 PM
Frenchican's Avatar
Car: 1989 IROC-Z
Engine: 5.7 TPI
Transmission: 5 Speed
I was pretty happy to learn how easy it was to change out the water pump on my '89 5.7 TPI. Just 4 bolts and one hose clamp. The only tough part was putting on the new serpentine belt even with the idler turned hard over. I was glad I took a few pictures with my cell phone on the belt routing.
Using a large screwdriver, I coaxed the belt on and I was done.
Old Jan 5, 2012 | 11:31 PM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
Re: Wow, water pump swap was way easier than I thought
Yeah that's the good thing about these cars. They're mad easy to work on.
Old Jan 6, 2012 | 05:03 PM
Damon's Avatar
The serpetine setups are by far the easiest water pump swap of any car I've ever worked on. Nothing obstructs access to it and there aren't any other brackets bolted to it like on old V-belt setups. Drianing and filling the coolant takes longer than changing the pump!
Old Jan 9, 2012 | 06:29 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
yeah,till you have to change the fuel pump!!!!
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
