motor mount installation help....
Old Jan 7, 2012 | 05:33 PM
crystal383's Avatar
I'm about to drop a freshly built small block in my 87 camaro. So i thought i might as well upgrade to the pollyurethane mounts while the engine is out.
The two bolts on the top part of the mount are really hard to get to. The k-member is hollow and there is a tiny hole off to the side that i'm trying to fish a wrench through to get to the bolt.
You would think changing them would be extremely simple. Is there any other easier way to get to the bolt? I know alot of ya'll on here have done this. I just want to know if there is a trick or special tool I don't know about.
Old Jan 9, 2012 | 11:38 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: motor mount installation help....
while i've done them before with the a-arms in place, its a bear. need to be creative with angled wrenches or sockets and swivel joints. when it came time to do it again on my last swap, the a-arms were removed. still not the most fun stuff to reach, but much more reasonable than trying to fight with those as well.
Old Jan 9, 2012 | 11:48 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
It is a pain in the butt, you can do it. I forget which holes I used in the K member but with a open end wrench, offset box end and regular box end I made it. I also used tape on the bottom of a box end wrench to hold the nut in place.
Old Jan 9, 2012 | 12:47 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
no real trick or special tool. a lot of reaching, straining, trying different wrenches, sockets, swivels, and a lot of cursing. like dan said, its a bit easier if you dont have the a arms in the way.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
