Power Steering Issues
Old Jan 9, 2012 | 02:50 PM
WhiteTrashStory's Avatar
Well, the power steering went out on my '92 bird. It was the first really cold night of the winter a few nights ago, somewhere around 30, and minutes after leaving in the car, the wheel became almost impossible to turn.
I'm guessing my first step is to replace the power steering box. Is there anything I should check before I do this?
Also, is there any tips on removing the box? Didn't seem as simple as I thought it would be when I crawled under the other day.
Old Jan 9, 2012 | 03:58 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Power Steering Issues
Hose failure?
Low or no fluid?
Old Jan 9, 2012 | 04:35 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
yeah, it could be a lot of things... including something as simple as the hose not being tight on the back side of the pump. it happened to me
check the fluid, if it's empty, fill it to specs, start the car, move the wheel lock to lock and see if you can tell where it's leaking from
if the pump is still full, you've got bigger problems
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Mar 18, 2019 08:29 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
