discontinued sparkplug wires
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
well,it seems that the aftermarket has thought it wise to stop making wiresets for anything GM made before 86.if you have the small cap HEI youre good to go HOWEVER if you,like me,have the large cap HEI and you wish to keep the ring on top of the dist. that holds the wires you,my friend are out of luck. i went to pep boys,autozone,advance,oreilleys and even the dealership looking for a correct wireset....no luck.so off to our local NAPA warehouse i go .they had a set that was close and they had another set that was also close.i ended up buying two sets in order to have all 8 wires with the correct terminals. i will post the part numbers shortly
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: discontinued sparkplug wires
acdelco 618N gm 12043815 if the top boot does not have the nipples they will still positively lock onto the cap terminals, most of the time the holders get throw away because the a pita.
http://www.ebay.com/itm/ACDelco-618N...#ht_1126wt_967
Hellbillydeluxe
Sep 22, 2015 09:58 PM
