Fuel tank capacity
Old Jan 12, 2012 | 06:00 PM
charliemccraney's Avatar
Car: 1988 Firebird Formula
Engine: 305 (LO3)
Transmission: 5 spd manual
Fuel tank capacity
During the Christmas holiday, my fuel pump died and I was out of town so I had to let a shop work on my car. When I had to fill up on my way home, I noticed that the filler was not installed correctly, which upset me. Then the tank took 18.754 gallons. I thought maybe the pump was inaccurate; it wouldn't be the first time I've encountered that. When I got home my gauge indicated that I had much more fuel than I should have and over the next few days, my mileage supported that it was in fact holding around 3 gallons more. I filled up again, 18.19 gallons once that was empty. I just added about 5 gallons so I can make it through this weekend before I drop the tank, and once again, my mileage supports the 3 extra gallons. So it really is holding about 3 more gallons than it should. I've never put more than 15 gallons in and that makes sense, it is (or was?) a 15.5 gallon tank. And it is much, much worse when cornering when the tank is almost empty.
I'm thinking they pulled some shady business because I don't see how a fuel pump replacement can also gain 3 gallons.
The car is an '88 Formula with tbi 305, 5 speed.
Is there a larger tank that fits or, since the filler is not on correctly, almost fits? Or is there some way that a stock tank can actually gain 3 gallons.
Is a part number stamped on the stock tank? If so, what should it be?
Does anyone have a picture of a stock tank?
Any of these should help me to positively determine that it is or is not stock once I have it out.
Old Jan 13, 2012 | 11:00 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: Fuel tank capacity
Well nobody has answered yet, so ill just give my 2c on the matter.
I did some looking around and found this thread, hopefully itll help a bit:
https://www.thirdgen.org/forums/body...tank-size.html
It doesnt make any sense to me that the fuel pump change would make your tank hold any more gas than before, let alone 3 gallons!! My only guess is you have a completely different tank. And it makes sense, it holds more, doesnt handle the same (heavier tank), and the filler wasnt fitting right.
I really cant think of any other reason. Maybe there is one, but im at a complete loss for an explenation for that other than a different tank.
When you find out more update us, im sure interested to see what it turns out to be.
Old Jan 13, 2012 | 11:07 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
No 2 ways about it.....15.5 on the stock tank so unless they replaced the tank with an aftermarket version that holds more? The pumps your using are lieing & cheating you out of $.
Old Jan 14, 2012 | 08:06 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
could it be a forth gen tank?
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Glowsock
Aug 26, 2015 12:28 AM
AkDrifted
Aug 17, 2015 07:45 PM
