guages Malfunction
Old Jan 13, 2012 | 02:43 PM
diamjim's Avatar
Car: 1992 RS Camaro
Engine: 383
guages Malfunction
Recently, I pruchase a 92 RS with a 383 (carb) and all the guages malfunction. Help
Old Jan 13, 2012 | 03:02 PM
projectredsled's Avatar
Re: guages Malfunction
What do you mean by malfunction? No power to them? Incorrect readings? Fluctuating readings? Pegged out? Have you checked the fuses?
Old Jan 13, 2012 | 05:00 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Sir, just relax. A technician has been dispatched.
...couldn't resist.
Old Jan 13, 2012 | 06:06 PM
diamjim's Avatar
Car: 1992 RS Camaro
Engine: 383
Odometer provides error speed readings. Tech needle swings back forward error readings. The oil pressure and fuel level guages are dead. The AMP meter is showing a normal charge.
Old Jan 13, 2012 | 11:07 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Have you done any troubleshooting so far?
Any chance you could post a pic of your gauges or maybe a vid?
I don't think I've ever seen a 92 with an AMP meter before.
Without any more clues I could guess that maybe the cluster connection is loose. A friend of mine recently suggested that a bad bulb could possibly cause malfunctions with some of the dash gauges.
Old Jan 14, 2012 | 04:04 PM
diamjim's Avatar
Car: 1992 RS Camaro
Engine: 383
Thank you for your help. The car has a 700R4 transmission in it. I'm thinking the car odometer is set up for a 4L60. The Tech is setup for a TPI fuel injection system distributor and the car has a regular carburator distributor in it. I'm thinking these modifications are causing the guages error readings.
sheachopper
Jul 31, 2019 11:27 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
