Newbie Connecting rod question
Old Jan 14, 2012 | 06:42 PM
Hick_101's Avatar
Ok so i am wondering if on my 400 sbc if my 350 connecting rods 5.7'' will work on my 400 engine. They have the Large journals. I feel like such a newb. thx for your time
Old Jan 14, 2012 | 06:54 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Newbie Connecting rod question
Not with stock 400 pistons ?
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can put the longer rods on a 400 crank but you need aftermarket pistons which move the wrist pins higher in the piston. Look at piston choices for 5.7" rods on a 400 crank.
Old Jan 14, 2012 | 06:57 PM
Hick_101's Avatar
running these pistons and yes on a stock 3.75 stroke crank.
http://www.ebay.com/itm/150713711944...ht_5214wt_1163
Old Jan 14, 2012 | 07:00 PM
Hick_101's Avatar
and rods like these with large journal.
http://www.ebay.com/itm/250971972501...#ht_500wt_1180
thx again
Old Jan 14, 2012 | 08:46 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
States they are for 5.7" rods
Old Jan 15, 2012 | 07:51 AM
Then the the combo will work.
Now all you'll need, is all the clearancing... the rod bolt shoulder will hit the bottom of the cyls, the oil pan rail, and probably the cam as well (probably will need a small base circle cam if you're like me and aren't willing to hack on the rods themselves).
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
Reborn756
Sep 4, 2015 03:42 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
