what compression ratio?
Old Jan 16, 2012 | 09:25 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
so im building a 87 305 roller cam motor ,and ive blueprinted the block except this;if i zero deck it and run cast flat tops and stock "416" heads,wtih your standard felpro head gasket.what compression rto might i expect with that setup?? i havent even given thought to a cam, what cam does a un modified TPI set up like???
Old Jan 16, 2012 | 10:00 PM
Re: what compression ratio?
Cast flat tops will have the usual .020" of extra "rebuilder" deck clearance added, on top of the stock .025".
So: 305 + .030"; flat top, 6cc valve reliefs; .045" clearance; .039" gasket; 58cc chambers: 8.17:1.
TPI is rather picky about cams, especially in a very low-compression 305 like that. I'd suggest a Comp "501" grind. http://www.summitracing.com/parts/CCA-08-501-8/
Don't expect miracles.
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
