gas cap changing performance?
Old Jan 18, 2012 | 07:29 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
on a hunch ,i know that our cars use a ccp system (carbon canistor). Ok, well i tried a vented gas cap tonight and noticed that the car acceklerated a little smoother but felt less torquey. I then put back my locking gas cap and immediately felt myself being pushed back in my seat with the torque i am familiar with. Strange. Anyone else exp. this? For the record, when i took off the vented cap i had no pressure release like i do with my regular cap. Maybe that pressure is good.
Old Jan 19, 2012 | 08:30 AM
ninetyone's Avatar
Axle/Gears: 3:42
Re: gas cap changing performance?
Anyone??
Old Jan 19, 2012 | 08:31 AM
ninetyone's Avatar
Axle/Gears: 3:42
No one experiences high pressure when they remove their gas cap? Havent any of you tried a vented cap because of this? any results?
Old Jan 19, 2012 | 09:58 AM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
guess not, i actually never heard of these, how much is the average cost so i can try one? my cap is pretty old and about itme for a new one.
Old Jan 19, 2012 | 10:10 AM
ninetyone's Avatar
Axle/Gears: 3:42
I bought my locking gas cap at Walmart, its a Stant. I got the factory cap and drilled two small holes in it for testing purposes.
Old Jan 19, 2012 | 11:42 AM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
aaww i see, yea. whitch would you reccommend for me? i like speed and lots of it,
Old Jan 19, 2012 | 01:23 PM
ninetyone's Avatar
Axle/Gears: 3:42
lol, its a stant locking cap,it was like $8
Old Jan 19, 2012 | 01:56 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Check the gas tank vent. It's on a piece of hose & hangs from the hose.
There is a discussion on it, but I don't recall the thread title, or exact location.
Seems easy to get to IIRC.
Old Jan 19, 2012 | 06:47 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
doesn't the gas tank vent into the charcoal canaster under the hood?i know its supposed to be under a vacumn to keep the gas fumes from leaking into the air.
Old Jan 19, 2012 | 07:22 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Fumes go to canister and are stored there.
Are purged to the engine under programmed conditions
If line to canister is blocked or system not being purged then common to get pressure build up in tank as noted
Old Jan 19, 2012 | 07:27 PM
ninetyone's Avatar
Axle/Gears: 3:42
yes,but someone else told me its normal to get pressure
Old Jan 19, 2012 | 07:28 PM
ninetyone's Avatar
Axle/Gears: 3:42
i was curious on how a vented cap would change performance and i did feel a difference. yes, i had no pressure when i went to remove gas cap,but car performed differently,just didnt feel as powerful
Old Jan 19, 2012 | 07:29 PM
ninetyone's Avatar
Axle/Gears: 3:42
i want to learn why?
Old Jan 20, 2012 | 08:59 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
Try an actual vented cap, not a reg cap with holes in it.
I'm about to order mine from mdm it's like 10 bux
My pressure is gone in the tank after I fixed my tank pressure valve
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
apo_bailon15
Mar 28, 2016 05:20 AM
johanlindgren
Aug 16, 2015 12:16 AM
