thinking about getting a jet piggy back performance chip stage 2. are these worth it or is it a scam
They are ok if you are stock. They just alter the spark tables a little bit and turn on fans earlier. Might feel a little difference.
for what little they do, there's better things to spend your money on, especially if the car is otherwise stock
u can get a custom chip burned for less i bet. a better program
how would you burn the chip
Quote:
you can buy the equipment and learn how to yourself,or get one made from pcmforless or tpichips.comOriginally Posted by mickeypatches
how would you burn the chip Quote:
Originally Posted by 1ADan
for what little they do, there's better things to spend your money on, https://www.thirdgen.org/forums/afte...orth-40-a.html
https://www.thirdgen.org/forums/tpi/...hip-stage.html
https://www.thirdgen.org/forums/elec...questions.html
There is a reason why they are always for sale in 3rd Gen Parts dept
http://www.gmhightechperformance.com...all/index.htmlOriginally Posted by vetteoz
good article
i gained more hp going to a stock aujp chip
i looked at pcmforless.com and the oldest they would tune is for an '86 and mine is an '84. could i still send it in or what?
Check with tpichips.com. Its always best to send in your own datalog from a program like TTS Datamaster. That way the chip burner knows exactly how your car is performing and what to adjust.
it looks like the chip burning is for tpi and tbi cars and my '84 camaro is a carb. might be wrong but from the websites i understand that it is for non carb cars
