Idles OK but driving issue
Old Jan 19, 2012 | 12:21 AM
aljohnsonii's Avatar
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
Anyone know why the car would idle fine but not drive down the road unplugged the maf sensor and problem got worst lookin for suggestions
Old Jan 19, 2012 | 06:43 AM
ex-x-fire's Avatar
Re: Idles OK but driving issue
Plug the sensor back in, clear the codes, see if any return.
Check the fuel pressure.
Old Jan 19, 2012 | 11:06 AM
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
I plugged it back in and 20 psi steady
Old Jan 19, 2012 | 12:11 PM
ex-x-fire's Avatar
Tpi need 36psi or more.
Tbi need 9-13psi.
If you have tpi, the pressure sounds low, before you replace the pump, pinch off the return line & see if your pressure increases (like a weak regulator).
Old Jan 19, 2012 | 12:23 PM
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
I had throttle body in car b4 I just switched it out I think that the fuel pump that's in the car needs to be upgraded to cover the other psi don't think that my pump is gonna work for tpi
Old Jan 19, 2012 | 12:28 PM
ex-x-fire's Avatar
So you swapped to a tpi type system? Yeah, 20psi is about max for a tbi pump. That where you need to start.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
