Fuel Injector Leakdown Time?
Old Jan 25, 2012 | 03:14 AM
Dark Ember's Avatar
Car: 90' Firebird Formula 350
Does anyone know the specification for how long is acceptable for fuel injectors to hold pressure?
I have pinched off the feed and return lines,(ruling out the regulator and the fuel pump) and in about 40 min the fuel pressure will drop from 50psi down to around 20psi.
Before I drop a bundle of cash on some new injectors(there are 4 that are slowly seeping fuel), I thought I would find out the acceptable range. I cannot find this specification anywhere.
Old Jan 25, 2012 | 06:50 AM
ex-x-fire's Avatar
Re: Fuel Injector Leakdown Time?
Thats not too bad. Make sure the fuel pressure regulator isn't causing the leak.
You can always get your injectors cleaned on the car, find a shop the uses BG44k injector cleaner, have them do a double dose.
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
Infested
May 22, 2018 11:56 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
