Can I use silicone for tpi plenum upper and lower gaskets?
Old Jan 25, 2012 | 04:13 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
I have a ported plenum, slp runners, and tpis big mouth intake.
I was trying to mill out the gaskets but they are now so thin. Can i just use silicone instead?
Old Jan 25, 2012 | 04:19 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Can I use silicone for tpi plenum upper and lower gaskets?
lol, silicone will work for anything. No guarantee that it will work best though.
If your gasket mating surface is thin, then why not build up the surface and reform it?
Even silicone needs surface area to hold a seal.
Old Jan 25, 2012 | 04:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by 305sbc
If your gasket mating surface is thin, then why not build up the surface and reform it?.
He means the gasket ( w/steel shim inside) itself is too thin to machine out to size of ported runner
Old Jan 25, 2012 | 04:28 PM
insomniac's Avatar
Engine: 5.7 L98
yeah that is what i mean...
Old Jan 25, 2012 | 04:43 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Ok you mean the stock runner gaskets. Yeah they are very limited.
You can grab gasket material from the parts store or hardware and cut out your own. I have to do this quite often so I keep a couple of rolls around.
RTV does pretty good with filling in gaps. Just give it a good 24 hours to set up before running the engine.
Permatex high-temp is good quality stuff.
1992 Trans Am
May 10, 2023 07:19 PM
MantyZ28
16
Dec 21, 2015 11:02 AM
toronto formula
Nov 10, 2015 06:17 AM
Sanjay
Aug 12, 2015 03:41 PM
