cam selection help
Old Jan 25, 2012 | 08:47 PM
phoenixxx602's Avatar
Car: 1986 z28
Axle/Gears: 3:73
cam selection help
this is what i got
.030 over 4 bolt main 350 1pc. rear main seal
Airflow Research (AFR) 195cc SBC Eliminator Street Heads
Comp cams (cam) Xtreme Fuel Injection, 268XFI HR13
comp cams chromemoly Magnum Pushrods
comp cams Ultra-Gold Aluminum Rocker Arm 1.6 Ratio
comp cams Hydraulic Roller Lifters
Speed-Pro Digital Diamond Profile Hypereutectic Pistons
Professional Products 80000 Power Force street harmonic damper.
Engine Pro Premium Billet Roller Timing Set
felpro Pre-Flattened Copper Wire Ring Head Gaskets
ARP bolts
AFR rocker studs
AFR Premium dual valve springs
tpis mini ram
5spd car daily driven
so the cam thats in it now (for sale) http://www.compcams.com/Company/CC/c...?csid=208&sb=0
has no power at lower rpm and i was thinking more duration would give me more torque so i wanna swap it with one of these
(1) http://www.compcams.com/Company/CC/c...?csid=215&sb=2
(2) http://www.compcams.com/Company/CC/c...?csid=177&sb=2
any advice or other cam suggestions are appreciated
Old May 27, 2016 | 08:02 PM
Mrich0908's Avatar
Re: cam selection help
Sorry didnt realize the date
Jorlain
Oct 8, 2015 01:57 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
