PCV making loud noise???? Vacuume prob?
Old Feb 2, 2012 | 01:32 PM
lethaldomestics's Avatar
Thought i had a bad valve but the pcv is making a tapping noise. Any idea what may cause this. I know its the pcv valve for sure. I removed it and the little valve inside was tapping rapidly.
Old Feb 2, 2012 | 03:09 PM
Re: PCV making loud noise???? Vacuume prob?
bump
Old Feb 2, 2012 | 04:24 PM
anybody
Old Feb 2, 2012 | 07:01 PM
also the pcv is new.
Old Feb 2, 2012 | 09:02 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Shows it is working correctly.
If you can't get it to rattle you have problems
Old Feb 2, 2012 | 09:24 PM
its real loud tho. hmm maybe ille try a different brand
Old Feb 3, 2012 | 12:55 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Have you checked your vacuum with a gauge?
Old Feb 3, 2012 | 10:21 AM
bombrcar's Avatar
Car: 1992 RS
Nothing to a PCV valve. Just a spring and plunger in a housing. take the vacuum hose off and hold your finger over the end. If you feel the vacuum surging you need to start tracing back to the vacuum source. Perhaps there is a restriction. If the vacuum doesn't surge then get a different valve. I know you said it's new, but perhaps the spring is bad or it's the wrong part number.
Old Feb 3, 2012 | 03:44 PM
Ok ille check it out and update.
theshackle
Sep 17, 2020 08:26 AM
pimp2303
Jul 27, 2017 02:03 PM
BlackBoulder
Aug 11, 2015 11:15 PM
BrianI
Aug 9, 2015 11:52 AM
