Small block 400 heads.
Old Feb 9, 2012 | 07:22 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
Found a set of small block Chevy 400 heads today. My question is, will these bolt on to a stock 305, and if so what advantage would they have? All I know is they have larger valves. If they will fit, is there anything I need to change or modify to get them on?
Old Feb 9, 2012 | 07:35 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Re: Small block 400 heads.
About the WORST heads made,and far worse to put on a 305.They have bigger valves,but also large 76cc chambers,which will KILL your compression.They flow bad,there is no good reason to use them for anything but a stock 400 or a doorstop.
Old Feb 9, 2012 | 07:36 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Bolt on fine; needt o drill some holes in the block to match steam holes in 400 heads
Whether they would be any good is a different story.
If chambers are too big then you will drop compression =less power
Casting # on 400 heads?
Old Feb 9, 2012 | 07:38 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The best mod you can do with those heads is pull one exhaust valve out, stick a rope thru the port and use it as a boat anchor...
Or just scrap them, prices are up !!!
Old Feb 9, 2012 | 07:58 PM
Engine: 350 S/B
I haven't bought them, apparently its not a good idea. Thanks guys. I'm about to pull the heads off my 305 to have then rebuilt. I've also found a set of another 305 heads already re-built, and ready to bolt on for $175. Pretty sure I have a blown head gasket. I'm looking for a decent set of headers also. Hint hint!
Old Feb 9, 2012 | 08:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Actually, that's the other way around. If you put any non 400 head on a 400 block, you need to drill the steam holes in the heads. You don't need to drill holes in a 305/350 block to use 400 heads on it. Those blocks already have proper coolant flow around the cylinders.
The 400's 882 heads are garbage. Door stops and boat anchors. They have zero performance potential.
Old Feb 9, 2012 | 08:23 PM
TTOP350's Avatar
You dont have to drill the holes in the block when using 400 heads.
You only have to drill the HEADS if you use them on a 400 block because of the siamesed cyl walls..
305s dont have siamesed cyl walls..
Old Feb 10, 2012 | 06:56 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by AlkyIROC
Actually, that's the other way around. If you put any non 400 head on a 400 block, you need to drill the steam holes in the heads..
Too many beers clouds thinking
theshackle
Mar 5, 2017 06:37 PM
Jorlain
Oct 8, 2015 01:57 AM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
