car not starting no spark
Old Feb 12, 2012 | 08:25 PM
AJHECK95's Avatar
Car: 1989 formula
Engine: stock lo3 305
Axle/Gears: dont know
i swapped a crossfire setup to a carb and i swapped the distributor to a mechanical one and now theres no spark anything will help
Old Feb 13, 2012 | 01:17 AM
Bigdeerock's Avatar
Re: car not starting no spark
I had an issue where I would get no spark turned out positive to the starter was loose never had the issue again. I would start there, and check to make sure ur grounds r good as well. Crack out the multimeter and start isolating from the battery on
Old Feb 17, 2012 | 04:07 PM
AJHECK95's Avatar
Car: 1989 formula
thanks for info i noticed your on your first restoration im on my first too good luck too ya
Old Feb 21, 2012 | 10:14 AM
AJHECK95's Avatar
Car: 1989 formula
i tested every thing turned out to be the ignition module in the distributor
now all i have to do is time it
Old Feb 21, 2012 | 10:30 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Its always the ignition module. I've had 3 of them fail on me over the years. 2 of them were Accel modules that failed within 6 months of each other. Make sure you buy a stock replacement type module. They seem to be much more reliable.
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
