Testing fuel pump pressure
Old Feb 12, 2012 | 11:38 PM
zzjakect's Avatar
Car: 1985 Z28
I've seen some info on testing the fuel pressure applied from the fuel pump. What I need is some step by step info on how to do it (since I'm completely ne to this is). I have a 350 (unknown year) with TPI, The car is a 1985 Z28. If I rent a pressure reading device from autozone where do I hook it up? Since the car does not start how do I check the fuel pressure?
I've put in a new pump, and will install a new relay as soon as I figure out where it is. Here are my questions:
Where does the fuel enter the engine?
Where do I connect the tester?
Where is the fuel filter?
Where is the relay?
Any help is huge to me.
Old Feb 13, 2012 | 01:19 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Testing fuel pump pressure
Where does the fuel enter the engine?]
Through the larger line on the driver side frame rail into the fuel rail.
On the rear of the fuel rail located on the pass. side of the engine near the dizzy. Looks a bit like a tire valve stem.
Under side of the car, driver side near the LCA.
Where is the relay?
I *think* it is one of the 2-3 of them located next to the power brake booster.
Perhaps spending 15 bucks on a Chilton/Haynes might be a wise investment.
Old Feb 13, 2012 | 11:38 AM
zzjakect's Avatar
Car: 1985 Z28
Thanks. I'm looking for a set of shop manuals to buy. With this project I really need a set.
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
