Need help with weird problem
Old Feb 13, 2012 | 08:12 PM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
I have a 91 z28 350 tpi and well it drives and idles fine but when im driving over a bump or if their is some what to much vibration my car does a strange thing. The gauges die , check engine light comes on, car just losses all power but does not turn of. Idnt no what this could be. Maybe a loose ground ? Some people have been telling me to change the pick up coil? What do u all think?
Old Feb 13, 2012 | 08:21 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Need help with weird problem
Well most likely it is electrical in nature. Years ago I had a 71 Camaro that had a similar problem. It turned out to be a hole in the cable from the battery to the starter. It was shorting out on the frame. Check yours for a similar issue.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
