Redoing fuel lines. I'm assuming I just need 1 line and 1 vent?
Old Feb 13, 2012 | 10:25 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
PRENOTE: I swapped to a carbed engine.
So, I'm moving my fuel lines to the passenger side. As of right now I have no charcoal canister and no return line. I'm assuming I can just run ONE line from the tank to the (mechanical) fuel pump, keep the vent that's already there, and just block the rest. Am I right?
Old Feb 14, 2012 | 01:05 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Redoing fuel lines. I'm assuming I just need 1 line and 1 vent?
So long as you are only using a mech pump
Old Feb 14, 2012 | 08:01 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I would suggest that you keep the CCP system.
It will eliminate a lot of fumes from being released from the tank. Easiest way to go is to use a canister from a truck, say a '90 full size Chevy van (they don't use a solenoid). And be sure to plumb it to 'ported vacuum' on the carb.
RBob.
Infested
May 22, 2018 11:56 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
mdtoren
Aug 23, 2015 12:52 PM
AkDrifted
Aug 17, 2015 07:45 PM
mdtoren
Aug 16, 2015 05:45 PM
