Fuel line
Old Feb 14, 2012 | 02:28 PM
AO91's Avatar
Fuel line
I have a 86 trans am 305 tpi, was working on changing the fuel filter when the line going from the filter back to the tank split open. What exactly do I need now to replace the fuel line and does anyone know about the difficulty/cost to do it myself. I am limited on tools but I would hate to bring it to a mechanic shop and get charges crazy $ to have it done for me. Thanks
Old Feb 14, 2012 | 02:41 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel line
not sure were your split happened at the o-ring flare fitting at the filter or the line. You can repair it with a 3/8 union fitting or a dorman 800-157.
Old Feb 14, 2012 | 03:08 PM
AO91's Avatar
Re: Fuel line
No where the fuel line bends and goes into the filter (like 3 - 5 in behind the fuel filter) right by the fuel filter bracket.
Old Feb 14, 2012 | 03:10 PM
Engine: Lb9
Transmission: M20
Re: Fuel line
looks like a 3/8 union will fix it than.
Old Feb 14, 2012 | 03:22 PM
AO91's Avatar
Re: Fuel line
Ok im sorry I am a learn as I go mechanic (don't know how else to word it) and I have never really messed with fuel lines before. Can you tell me more about the 3/8 union and how it works and/or possibly a link explaining what it is and how to use it. Thanks
Old Feb 14, 2012 | 03:31 PM
Engine: Lb9
Transmission: M20
Re: Fuel line
use a tube cutter cut out the bad spot insert the union fitting, bobs your uncle.
http://www.youtube.com/watch?v=pdb3Oy8bxO0
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
