knock sensor help
knock sensor help
hi ive fitted after markets headers and the knock sensor is very close i think will melt ,i carnt swap it over to the other side has same problem ,is there anywhere else i can mount it its a 305 tpi engine ,is it right i can bolt it just above the oil filter housing ,is this already threaded to the right size
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: knock sensor help
you can relocated it there but it looses alot of its sensitivity.
http://www.summitracing.com/parts/RFW-KB41/
FormulasOnly
Sep 10, 2015 09:07 PM
