2.8 vacuum
Old Feb 15, 2012 | 11:59 AM
88cam23's Avatar
2.8 vacuum
trying to replace vacuum lines and I noticed I have this valve or what ever. It has lines going to it and a opening on the side of it. trying to figure out where that goes?
http://imageshack.us/photo/my-images...215121144.jpg/
There is alot of other tiny leaks can I just plug and cap them to see if the car runs better?
Old Feb 15, 2012 | 06:22 PM
ex-x-fire's Avatar
Re: 2.8 vacuum
Looks like an egr valve, disable it by plugging the vacuum hose. Then drive to see if it runs better, then figure out the problem afterwards.
Old Feb 15, 2012 | 07:27 PM
88cam23's Avatar
Re: 2.8 vacuum
I thought the egr valve is attached to the exhaust manifold? This thing is just hanging there. Ill try plugging them in the morning.
Old Feb 15, 2012 | 07:29 PM
magicmerlin's Avatar
Car: 89 RS -95 camaro sc
Engine: 2.8 - 3.4
Re: 2.8 vacuum
its a heater valve
Old Feb 15, 2012 | 07:32 PM
88cam23's Avatar
Re: 2.8 vacuum
I am thinking about removing the complete intake to replace the gaskets and check the injectors. I am just a little nervous on doing so with all the brittle vacuum lines every where.
88cam23's Avatar
Re: 2.8 vacuum
Originally Posted by magicmerlin
its a heater valve
Ok where would that side port go to? It has a opening for a hose to be connected to it. Thank you
Edit. I think its for the AC which I dont use so I think ill just plug it.
Old Feb 15, 2012 | 07:35 PM
Engine: 2.8 - 3.4
Re: 2.8 vacuum
water hose from heater core go into it others come out of it go to the engine vacume hose opens and closes it to make heater work
Old Feb 15, 2012 | 07:37 PM
88cam23's Avatar
Re: 2.8 vacuum
Ok thanks alot
Old Feb 16, 2012 | 06:08 AM
ex-x-fire's Avatar
Re: 2.8 vacuum
plastic egr valve, yeah right.
Old Mar 4, 2012 | 06:21 PM
88cam23's Avatar
Re: 2.8 vacuum
Ok Instead of opening a new topic I wanted again to ask for help on this.
almost all of my lines are brittle and breaking every where. I am having trouble even with a diagram.
Now on my upper intake I have a T coming off the back of it. One part of the T is going to my brake booster?
Then the other side(passenger side) of the T has nothing connected to it? Does any one know what plugs in there?
Then on the lower intake near the distributor I have a vacuum port with a T that connects a BIG line from the TB then connects to the line that has the PCV. is that correct and how it should be?
Old Mar 4, 2012 | 07:57 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: 2.8 vacuum
You should have a vac line diagram on the hood but heres what your looking at
Old Mar 4, 2012 | 11:54 PM
88cam23's Avatar
Re: 2.8 vacuum
wow thank you thats even better its more specific. I notice it says 86 I assume same routing for the 1988? I know I have the diagram but it seems like who ever owned it before spliced and diced and I have more vacuum lines then carter has pills and not sure what to do with them I guess ill replace it like the above pic and whats left over ill throw away.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
usafirebird
Sep 29, 2015 11:58 PM
dusterbd
Sep 29, 2015 08:40 AM
