Exhaust pops
Old Mar 1, 2012 | 12:34 AM
Albinobatmobile's Avatar
Exhaust pops
Wheni drive the exhaust pops and it stalls out.! Possibly because I may ha e put a wrong spark plug wire. I thought all the wires are the same as long as it is long enuff. Are they all the se am just different wires
Old Mar 1, 2012 | 09:38 PM
VandykeT/A's Avatar
Re: Exhaust pops
You probably crossed one.
Old Mar 2, 2012 | 09:01 AM
hilltop530's Avatar
Car: 1987 Iroc Z28 Camaro
Engine: 5.7 TPI
Re: Exhaust pops
firing order needs to be checked. Also be sure that you have proper connections at the plugs and the distributor. The boots on plug wires can be a pain. (New or old)
Old Mar 4, 2012 | 04:14 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Exhaust pops
Careful with what people still call plug "wires", If I had to make a comparison, it's like calling compressed particle board "wood", mess with enough and it falls apart. Today's "wires" are made of compressed carbon particles and will break down the more you pull, twist, and bend them. I call them "carbon plug cables" and I change them when I change plugs.
Old Mar 4, 2012 | 05:12 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: Exhaust pops
dont seem to me it would stall out cuz of crossed wire. are u sure u didnt accidently unplugged a vacuum line?
Old Mar 4, 2012 | 08:25 AM
VandykeT/A's Avatar
Re: Exhaust pops
When I crossed number 5 and 3 my car would drop down to around 300 rpm when I let off at low speeds like it was going to die and would stumble when i first gave it fuel. That was also with open headers and no 02 sensor hooked up to.
Old Mar 4, 2012 | 05:14 PM
Re: Exhaust pops
I actually did my firing order wrong! It still stalls out though and it's t the shop. He said possibly the timing and need tune up. Makes sense idle was rough before it started stalling out. It's 22 years old . What does be mean by the timing? Idid the plugs the wires. A fuel filter the oil and filter and the air filter. I felt like a real man under the hood.
Old Mar 4, 2012 | 08:07 PM
Fritomaster's Avatar
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Re: Exhaust pops
Check for vacume leaks?
Old Mar 4, 2012 | 08:34 PM
VandykeT/A's Avatar
Re: Exhaust pops
If it idles rough, misses consistently while driving and we're talking about a TPI motor. I would just about bet anything you have an injector problem.
Old Mar 5, 2012 | 04:46 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: Exhaust pops
didnt know it was tpi. is it throwing any codes?
db057
Apr 28, 2019 07:45 AM
sailtexas186548
Feb 17, 2017 03:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Randomtask2
Sep 10, 2015 08:37 AM
89fast5oh
Sep 8, 2015 09:55 AM
