valve seal change,now high oil pressure
Old Mar 4, 2012 | 01:32 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
yep, finally got it to quit puffing blue smoke,but now it has high then usual oil press. step on the gas and it needle goes up. 50mph and the needle shows it at 60 lbs of pressure afraid to go any faster for fear of blowing it up. fyi b4 i did seals it ran 30-50lbs only.
Old Mar 4, 2012 | 04:48 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: valve seal change,now high oil pressure
Something wrong
Valve seals only stop the oil leaking being sucked into the cylinders ;that oil is not under pressure ,
just floating around under the rocker cover so no relationship to engine oil pressure.
Have you checked your OP gauge against a known working one?
Gauge or sender may be faulty
Old Mar 4, 2012 | 05:09 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
gauge is good. that much i know.
Old Mar 4, 2012 | 07:32 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
i would go to the parts store and buy a mech. gauge and hook it up to make sure.
Old Mar 5, 2012 | 02:09 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Your oil pump has an internal bypass valve to control pressure. It keeps the pressure from continuing to climb unless it has been blocked by debris or has somehow jammed or seized.
If it was me I would go ahead and rev it up to see how high the pressure goes. You really don't have much to worry about because it's very unlikely for an oil filter to burst at anything under 100 PSI. You will see on your gauge before accidentally going over that.
If it stops going up around 60 PSI then you're fine.
Old Mar 5, 2012 | 07:18 AM
I wouldn't bother with a mech gauge.
Here's the troubleshooting steps involving one of those:
1. Observe stock gaug: reads funny.
2. Go to store & buy mech gauge. $$$
3. Install mech gauge. $$$$ + hrs, various fittings, mess with everything, etc.
4. Discover stock gauge is indeed wrong. Well duh.
5. Begin troubleshooting.
6. ???? Dink around a little, determine the only way to troubleshoot it is, by replacement.
7. Do the obvious: go to parts store and buy oil pressure sending unit. ¢¢¢
8. Remove all the mech gauge crap.
9. Replace OPSU. (no hrs, just a couple of min)
10. Gauge now reads right.
OK, now that you've had some time to think about all that, explain how steps 2 - 6 and step 8, add ANY value WHATSEOVER to the process.
Skip all that. Move directly from step 1 (which is where you are now) directly to step 7; then to step 9 & 10.
89GTAOz
May 16, 2020 09:31 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
db057
Aug 22, 2015 08:17 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Exxon Limited
Aug 9, 2015 08:13 PM
