Speedo, tach, odometer, not working
Old Feb 15, 2012 | 05:19 PM
Slayerx666's Avatar
I searched on here and it seems to be the vss, but I want to make sure. When I turn the key to on, the tach jumps to 2000rpms-5000rpms, then when I start it, it pegs out. It's also pegged out when it's off. The speedo also does not work, along with the odometer. It's a 91 RS with a 305 and auto trams. Is this problem likely the vss?
Old Feb 16, 2012 | 09:32 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The VSS has nothing to do with the tach.
Is the SES light coming on? If so, have you checked the trouble code(s) being set?
You may have a common problem in the instrument cluster or wiring to it, or you may have two different problems.
Old Feb 16, 2012 | 09:53 AM
Slayerx666's Avatar
Re: Speedo, tach, odometer, not working
no check engine lights. thats strange. i wouldnt even know where to start
Old Feb 16, 2012 | 10:26 AM
five7kid's Avatar
Cluster power, cluster grounding, damaged connectors/wires would be a good place to start.
Old Feb 17, 2012 | 09:48 PM
K4KAK's Avatar
My 90 model camaro rs is the same way and my security light is on as well. My tach showes 5000 at idel and goes up from there.. Speedometer doesnt work at all.. I have a 305 with 4 barrel and 5 speed transmission.. Help me too.
Old Feb 20, 2012 | 07:04 AM
SKRILLEX's Avatar
Car: 86 Camaro Z28
everything is working for me excpt my speedo and my odometer,, no check engine lights i guess imma start tracing wires
Old Feb 20, 2012 | 10:36 AM
Keegan84's Avatar
Car: 84 trans am
Engine: 350 bored .020 over
Transmission: TH350 w/ stage 2 B&M shift kit
Axle/Gears: 9 bolt/3.27
Make sure the speedo cable is hooked up to the transmission lol
Jeremys87
Jul 14, 2022 09:08 PM
Wade787b
Sep 29, 2015 01:15 PM
beachrodder
Aug 7, 2015 04:27 PM
kyle5647
Aug 7, 2015 03:08 PM
stalkier
Aug 7, 2015 04:49 AM
