High idle. L98
Old Feb 17, 2012 | 01:00 PM
VandykeT/A's Avatar
High idle. L98
A friend of mine bought a bone stock L98 camaro that idles high. Is there a common thing that causes this or should I start looking for vaccumm leaks and what not. No check engine light or anything.
Old Feb 17, 2012 | 01:58 PM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
Re: High idle. L98
check the water temp sensor will make car idle high if not working
Old Feb 17, 2012 | 05:21 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: High idle. L98
Definitely look for vacuum leaks. I don't know much about your L98 but on my TBI advancing the timing with out backing down the idle speed screw causes it to idle high.Put a timing light on it and see if it has been moved. If it has back it down some.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
pacoelrapido
Sep 11, 2015 02:41 PM
89fast5oh
Sep 8, 2015 09:55 AM
scottmoyer
Sep 7, 2015 07:06 PM
