compression ratio?
Old Feb 20, 2012 | 08:29 PM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
compression ratio?
ok so i am building my first engine(355ci vortec) and i was just wondering how do i fined out the compression ratio of the motor? is there a math formula that i could do to fined it ?
Old Feb 20, 2012 | 08:44 PM
Re: compression ratio?
It's pretty trivial really; junior-high arithmetic.
But there's "calculators" ALL OVER the Net, that you can put your engine's measurements into and they'll figure it out. Problem is, if the numbers you put in aren't accurate, the ones you get out won't be either.. Garbage in, garbage out. If you "guess", "estimate", "assume", or any of the rest of that about EVEN ONE of the various measurements, then a "calculator" is worthless.
I thought there was one on this site somewhere... they're SUPER EASY to write in Javascript... the one I wrote, I used Excel... but I know just about all the piston mfrs have them. Keith Black at www.kb-silvolite.com for example has an easy-to-use one.
Old Feb 20, 2012 | 11:19 PM
clean92rs's Avatar
Car: 92 camaro RS
Engine: Vortec 355,262/268 cam,670holley
Transmission: 5speed
make sure you know how far in the hole ur pistons are, the cam specs, gasket thickness and such and just plug it all into a calculator online.
Old Feb 21, 2012 | 12:00 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Download and install this one
http://cochise.uia.net/pkelley2/dcrvb6.zip
Old Feb 21, 2012 | 04:44 PM
kill4thril's Avatar
Engine: 355ci
Thank you
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
