It just shut off going down the road
Car: 1989 Camaro RS
Engine: 5.0 ltr. 305 TBI stock with holes d
Transmission: T-5 five speed
Hey guys, so I was driving my T/A down the road, when all of a sudden, the car shut off, all the gauges quit working, the fuel pump as well, and the headlight buzzer remained on the whole time. The car will still crank and run, as long as I have straight power going to the fuel pump. I was just wondering if anyone else had any similar problems and if so what they did about it. I'm not sure where to start. I know that he ignition spots on the fuse block are not getting any power. Maybe it's an ignition wire? I checked all the fuses and relays, and came up with nothing. Any kind of info would help a lot. I don't want to dive into the wiring until I know for sure what the problem is. Thanks a ton guys
'92 Trans Am Ws6, 305 TPI bored .030 over
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: It just shut off going down the road
There should be another fuse for the fuel pump towards the passenger front headlight. Also make sure none of the wires coming from the oil pressure sensor are burnt or cut.
Sounds like a fusible link...
Do a quick search of the last month or 2 of this forum, on my userID and those 2 words.
Gunner242
Dec 25, 2015 04:49 PM
