83 will not run HELP !!!!????
Old Feb 22, 2012 | 11:09 PM
83camaro_D's Avatar
i have an 83 2.8 v6 i have just replaced plugs wires and other parts and it wont run i had it running a week ago with a bad carb and now i put on a brand new one and it will turn over but not fire and keep running. i have fuel,spark but no lovely purr what could be the issue and how can i fix it any info will help thanks ~D
Old Feb 23, 2012 | 06:21 AM
ex-x-fire's Avatar
Re: 83 will not run HELP !!!!????
Look down into the carb (eng. off w/ the choke open) & move the throttle arm, do you see fuel squirting out?
Recheck you firing order.
Old Feb 23, 2012 | 09:17 AM
83camaro_D's Avatar
yes i have gas in the carb and the timing was set by a like 70yr old corvette guru he swears that its right so we shall see what happens thanks for the extra info
Old Feb 25, 2012 | 08:14 AM
83camaro_D's Avatar
So I did a compression test and have next to none time for an engine swap any good ideas???? I was thinkin 327 or 427 both of wich would be supercharged
Old Feb 25, 2012 | 08:34 AM
ex-x-fire's Avatar
Make sure the valves aren't over adjusted.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
