hopefully the final issue
Old Feb 26, 2012 | 08:03 AM
cactusman92's Avatar
Car: 1991 Chevrolet Camaro Z/28 (Project
Engine: 5.0L 305
Transmission: 700R4 W/ B&M shift kit
Upon recently do head gaskets i had the engine together and the one side started leaking so i took it apart again and tried again this time no leak i put the engine back together the exact way that i did when it leaked it ran great when it was leaking so i put it together exactly how i did it before i did the rocker arms properly and everything is properly toruqued timing sounds correct and appeared correct with the timing light the problem is its idleing really low and choppy and im hearing little pops in the exhaust it shoots out a bit of smoke but i think its from when they leaked all the **** that got in my and its just blowing it out i am hoping anyone can help me out troubleshooting this none of the gaskets are leaking but im sure it will end up being something really obvious...
Old Feb 26, 2012 | 10:33 AM
Re: hopefully the final issue
Sounds like plug wires #5 & #7 are swapped.
Study my signature carefully and incorporate its lesson into your troubleshooting technique.
Old Feb 27, 2012 | 07:58 AM
Engine: 5.0L 305
ill be sure to check that first and while at that all the others as well hopefully that turns out to be the issue
Old Feb 27, 2012 | 09:24 AM
Engine: 5.0L 305
The great news that it wasn't those 2 being swapped it appears all of the wires were one space over now it runs fine thanks for the idea of the place to look
Cornholio7979
Sep 20, 2018 02:31 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
sunbound
Sep 5, 2015 11:52 AM
