Engine power cuts out at 2500 to 3500 rpms
Old Feb 26, 2012 | 03:11 PM
Dwalter191's Avatar
Did a little work to my 86 camaro its got a 305 now the power cuts out around 2500 to 3500 rpms i am running out of ideas the engine light is on and the code reader has read anything from the mass air flow sensor to now the o2 sensor any ideas would help it is now reading code 45 but it has a new 02 sensor let me know what you think.
Thanks Dustin
Old Feb 26, 2012 | 03:15 PM
Dwalter191's Avatar
Re: Engine power cuts out at 2500 to 3500 rpms
exhaust is running rich
Old Feb 26, 2012 | 04:26 PM
Damon's Avatar
If you've traced down lots of codes that don't make much sense you might want to get a new ECM, but not before you check all your grounds.
Also, in some situations the module inside the distributor can go flaky and give you certain "windows" in the RPM range where they break up or lose power. Pretty rare, but it can happen.
Old Feb 26, 2012 | 04:58 PM
Dwalter191's Avatar
Any suggestions on how to go about fixing either of those I just replaced the distributer coil and what not so I'm just lost at this point.
Old Feb 26, 2012 | 08:45 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Can you elaborate on this?
What all did you mess with in the process?
Pull any vacuum lines or electrical connections? EGR unhooked?
Old Feb 26, 2012 | 09:34 PM
Dwalter191's Avatar
Well the engine was rebuilt some vacum lines were bypassed before the rebuild and didn't have problems then and there is an egr delete kit All sensors are brand new and all electrical is hooked up.
theshackle
Sep 17, 2020 08:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
