Short Spark Plugs
Old Feb 28, 2012 | 12:03 PM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
Short Spark Plugs
I've been searching this for a while and, while there are a lot of threads on the matter, I still have no answer. I have hooker long tubes and I need shorty spark plugs. I've been using Accel 8199 plugs but they fail really often and I am ready to try some other plugs.
Anyone know about a spark plug that would be equivalent to the accels in terms of length and heat range?
Old Feb 28, 2012 | 12:41 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Re: Short Spark Plugs
NGK has plugs that are equivalent - UR4, UR5 or UR6. The 4 is hot and the 6 is cold.
I ditched my Accel shorty plugs long time ago.........they're terrible. You won't regret it.
Old Feb 29, 2012 | 07:21 AM
Car: 1991 GTA
Thanks a lot. Found some NGK UR4GP and after custom making a tool I finally installed #6 and #8 plugs. Those Accels kept fouling and at $30 a set I just gave up on them. Thanks again.
Old Feb 29, 2012 | 07:36 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Not a problem.....and a custom spark plug tool is the way to go, I made one also.
Old Feb 29, 2012 | 07:07 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I'm not a fan of Accel spark plugs at all, but my first concern would be to find out why they were failing and/or fouling.
Have you done any datalogging to verify that your ECM is going closed loop?
What sort of BLMs are you seeing at idle?
Did you switch to a heated O2 sensor when you installed your long-tubes?
Old Feb 29, 2012 | 07:10 PM
jwdomino's Avatar
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
ar133's are pretty short, almost as short as the accels, but non resistor plugs means rfi and if you have some electronics or even your radio, will have static. I have run accels for quite some time, never had a problem with them
Old Feb 29, 2012 | 09:04 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
If you're using shorty plugs because they're simply difficult to get to, try that cheap harbor freight socket set with the thru-socket ratcheting wrench. I've gotten myself one and its been mostly useless for everything else I've tried it for, but it makes changing spark plugs such a breeze I would have paid twice as much to get it.
Then you can use regular plugs.
But there may be another reason your plugs are failing that isnt the brand. Just saying I had an awful time with my plugs and wanted shorty plugs, but I found this goofy socket from harbor freight that made it a breeze.
Granted, Ive got Hedmans, so I dont know if the Hookers physically try to occupy the same space as the spark plug... in which case a goofy socket wrench wont help much.
That said, I can have all plugs replaced in a matter of 5 minutes with that thing, so I'd hope my post is not a total waste of time if I can help my fellow thirdgenners with a fairly tedious aspect of the hobby.
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
Bryan F
Aug 18, 2015 02:28 PM
