takes a big gulp then revs...?
Old Feb 28, 2012 | 03:06 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Just switched to bosch III's and installed adjustable FPR from south bay. Car idle pressure is 38a psi and jumps to almost 49 on throttle pump. No leaks. Engine is 91 305 tpi map setup. When I hit throttle, you can hear the engine take a big gulp and then vroooom. It didn't used to be delayed this bad. I know map systems have a little more "lag" but this seems a little excessive. timing is at 10 BTDC. Engine runs best at that setting when setting base timing. Tps sensor is at. 56v. IAC is new. Is this normal. Can't drive on roads yet up here, but it will break tires loose in barn. No backfires. Thanks guys
Old Feb 28, 2012 | 06:10 PM
Re: takes a big gulp then revs...?
Anyone? Bump
Old Feb 28, 2012 | 06:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Start by staying away from 7-11...
Honestly, though, you only give us 3 hours to respond to your unique situation? Really, many of us have barely gotten off work. Give us a chance to relax a little and check FB first. We don't do this for a living.
But, '91 TPI + MAF + mods = tune.
Old Feb 28, 2012 | 06:25 PM
Sorry honestly. But its stock map. Not maf
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
middian
Sep 5, 2015 01:42 AM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
