91 fuel pump trap door
Old Feb 29, 2012 | 09:45 PM
mintc's Avatar
i am wanting to replace the fuel pump in my 91z and dont want to drop the tank i seen somewhere about how to cut the top out of the hatchpan and it had the dimensions and stuff but i cant seem to locate it anymore. any1 got any info on this surgery
Old Feb 29, 2012 | 09:57 PM
mrrman's Avatar
Re: 91 fuel pump trap door
http://ls1tech.com/forums/fueling-in...-98-fbody.html
http://ls1tech.com/forums/lt1-lt4-mo...ut-sparks.html
http://ls1tech.com/forums/lt1-lt4-mo...ions-help.html
http://ls1tech.com/forums/lt1-lt4-mo...-mod-pics.html
Here are some posts on it...I did this on my 87 TA...no regrets
Old Feb 29, 2012 | 10:03 PM
mintc's Avatar
would you cut in the same place tho? that vid was from a fourth gen camaro
Old Feb 29, 2012 | 10:19 PM
mrrman's Avatar
mine is a third gen...I would remove the carpet and look at the current position where the sending unit is located...its pretty close to what is shown....or do some searches for 3rd gen trap doors on this forum and thirdgen.org, ls1tech.com, firebirdnation.com
Old Feb 29, 2012 | 10:25 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
All the pic info you'll need to located the pump access door.
http://s119.photobucket.com/albums/o...%20GTA/Engine/
Old Mar 2, 2012 | 05:44 AM
mintc's Avatar
what about the metal fuel lines? how are they gona come out that little hole?
Old Mar 2, 2012 | 09:26 AM
Car: GTA
They won't, hence the need to cut the lines & add connections to the hard lines. Typically the entire tank is dropped one last time to do the hard lines connections so that dropping the tank isn't needed again. There has been some people successful in cutting the lines through the "small" hole & doing the disconnects without dropping the tank, but I don't know how they are accomplishing that.
Old Apr 19, 2012 | 04:35 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
My plan is to cut the fuel lines at the sending unit area AND under the car, then replace those lines with braided steel fuel lines and AN fittings. That should enable me to, if I need to replace the pump, just open the panel, disconnect the lines and pull the sending unit out. Easy, peezy- lemon squeezy!
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
