91 speed sensor
Old Mar 3, 2012 | 04:52 PM
mintc's Avatar
91 speed sensor
ok my car set for 3 years and i just recently got it running and now the speedo dont work right , when i get up around 50mph it will read about 5 mph, do you all think its the sensor gone bad from sitting that long , can i just pull it out and try to clean it?
Old Mar 3, 2012 | 04:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 91 speed sensor
probably the gauge, but you can try to clean the sender, but its electric, so its a sealed unit, you can really take it apart.
my bet is on the cluster, not the sender.
edit
are you saying at 50 it drops to 5 or its only reading 5 at 50 mph?
Old Mar 3, 2012 | 05:03 PM
mintc's Avatar
Re: 91 speed sensor
at 50 it climbs up to 5 on the speedo at 60 climbs up to around 10
Old Mar 3, 2012 | 08:44 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: 91 speed sensor
the sensor would be the thing i would try first . good luck.
Eric2ndGen
Nov 5, 2015 01:51 PM
GTAman
Sep 21, 2015 09:57 AM
angel2794
Sep 8, 2015 06:22 PM
IROCtometal
Sep 2, 2015 02:01 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
