Engine noise
Old Mar 5, 2012 | 11:13 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Engine noise
Well I haven't been on in a while but I have been around. Anyway start my car up for the first time in months because it was finally nice out and right off the bat I notice a loud sort of smacking sound as some would call it coming from the passenger side of the engine. It increases in speed as the RPM goes up and is kind of loud. I know it cant be knocking because my Intrepid threw a rod and it sounds nothing like it. I was thinking maybe the valves or something but I really don't know very much about engines. Anyway its a stock factory L98 and it is full of oil and was changed about 2k miles ago. Any ideas???
Old Mar 6, 2012 | 06:36 AM
ex-x-fire's Avatar
Re: Engine noise
Remove the drive belt(s) & restart the engine. Might have a noisy pump or alternator.
Old Mar 6, 2012 | 07:05 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: Engine noise
+1 on this, lifter could have commited suicide over the winter also.
Old Mar 6, 2012 | 09:40 PM
Re: Engine noise
Ugh I am hoping that if it were to be any of those things it would be the alternator. Just because it involves a little less engine tearing.
Old Mar 7, 2012 | 02:49 AM
Fritomaster's Avatar
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Re: Engine noise
Yo i just fixed a knock just like that on my car
Yours sound like this?
http://www.youtube.com/watch?v=aI3lT6ObkSs
Old Mar 7, 2012 | 12:17 PM
Re: Engine noise
Um I will have to check on that but mine is not that prominent as yours is.
Also, yesterday I went out to start it for a friend to show him the sound that the car was making. I start the thing and it runs nice and smooth and isn't making the sound. So I let it run for five minutes and give it a few light revs and still no funky sounds from the engine. Then again it did reach 70 degrees outside so I am not sure if it is determined by temperature or something.
So this thing is starting to confuse me.
Old Mar 8, 2012 | 12:00 AM
Re: Engine noise
So do you want me to remove all the belts? Well excluding the timing belt of course but the rest then? So I guess it would still work theoretically except it would just run off the battery entirely then.
Old Mar 8, 2012 | 02:37 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Engine noise
have you tried a mechanics stethascope or a something similar to isolate the noise?
Old Mar 8, 2012 | 05:55 AM
ex-x-fire's Avatar
Re: Engine noise
Yes remove the belts & run briefly to see if the noise is still there.
Old Mar 8, 2012 | 06:22 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Engine noise
Is it possible it's an exhaust leak? They can make really odd noises sometimes.
Is it in a steady rhythm? If so let the car idle and count how many times it does it in 10 seconds. Multiply by 6, and you get an occurances per minute number. See if it's 1/2 the RPMs or if it matches teh RPMs. That will tell you whether it's bottom end related, or valvetrain related.
Old Mar 8, 2012 | 08:59 AM
Brando5641's Avatar
Re: Engine noise
If it only does it when it is cold it could be piston slap or a bad lifter that doesnt like the thick oil when its cold.
Old Mar 8, 2012 | 11:10 PM
Re: Engine noise
It is a steady rhythm and I am sorry I am slow on my responses but results will have to wait until tomorrow at around noon.
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BlackBoulder
Aug 11, 2015 11:15 PM
