Horsepower estimate
Old Mar 9, 2012 | 08:16 PM
marcos beltran's Avatar
Horsepower estimate
I was wondering if anybody can give a an estimate as to how much horsepower I am pushing with this engine combination. I have a 89 formula that had a tbi 305 engine in it. I pulled it out and put a 350 out of a 79 truck in it. The motor was bored to a 355 and all the bottom end is pretty much stock. It has edelbrock cam duration 278/288, lift .420/.442, edelbrock dual plane performer intake, and edelbrock 600cfm carb. It has longtube headman headers and is a true dual exhaust with 40 series flowmaster mufflers. I was also curious as to how much hp will I gain if i go and do the vortec heads swap since they are pretty cheap to come by. Thanks for any help.
Old Mar 10, 2012 | 12:43 PM
Re: Horsepower estimate
Any body?
Old Mar 10, 2012 | 04:55 PM
gmstrong's Avatar
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
your probably at 240 at the wheels,With vortecs you should be up to 260+.
Old Mar 10, 2012 | 05:19 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Just wonderin... What valve springs you runnin?
Old Mar 11, 2012 | 01:39 PM
The heads are stock, not sure.
Old Mar 11, 2012 | 02:14 PM
lemons racer's Avatar
Car: 86 Camaro, IROC springs & bars
Engine: Mild 350,Q-jet,headers
Transmission: M-21, 12#flywheel
Axle/Gears: 98 7.5, 3.73 torsen.
You have kind of a strong cam for a low compression engine, big chambers & dished pistons if stock, the Vortecs would be a good choice but even with them I'll bet you'll only be at about 200 or a little more.
If you go with flat tops with the proper compression hight which as I remember is 1.560 for a standard small block, that puts the piston .020 down the hole with say an .018 shim head gsk. which makes the quench area work properly you should be at close to 300.
My last 24Hrs of Lemons engine used TRW flat tops, World 68cc heads, 262 Duration 421-444 lift with 1.5 shortys & 3" mandrel Flowmaster exh, Edelbrock performer with a 730 Quadrajunk carb, made 218 chassis HP at Thunderhills chassis dyno.
PurelyPMD
May 5, 2016 04:57 PM
dbrochard
Sep 25, 2015 04:56 PM
skip91
Sep 24, 2015 03:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
formula_novice
Sep 5, 2015 03:58 AM
