stock 882 heads vs GM bowtie heads
Old Mar 13, 2012 | 09:51 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
quick question. i have a 350 bored 40 and decked 10. it has flat top pistons with a crane cam 478 lift with a 2000 stall. a demon 750 double pumper with a 1" spacer on a edelbrock performer dual plane intake, hooker comp headers and 2.5 inch exhaust.
i have a set of stock 882 heads with z28 springs.
i recently purchased a set of gm bow tie heads with 202 valves. i bought them for 400 bucks ready to go with guide plates and screw in studs.
i got them from the guy who purchased them new in 1998 and had them ported and polished and rebuilt last summer. they have 4 runs through the 1/8 since the rebuild
will these heads out perform my 882 or should i sale for a small profit and keep what i have? currently my car has no problem turning 6000 rpms and it feels quick. however, i have lost 4 races and i'm not feeling much love for my IROCZ
any opinions or advice is appriciated
Old Mar 14, 2012 | 03:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"...lost 4 races"? As in, street races?
Old Mar 14, 2012 | 03:36 PM
mpb74's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 342
Re: stock 882 heads vs GM bowtie heads
street cars with street tires racing at the Jefferson Pageland 1/8 mile.
Old Mar 14, 2012 | 05:36 PM
grumpyvette's Avatar
anyone that looks at that post really needs a great deal more info to make even a wild guess at the correct answer
whats your car weight with you in it?
whats your current ET and trap speed?
whats your current compression ratio?
whats your rear gear ratio?
what tires do you use?
what rpm do you launch at?
chances are good that the new heads will be a minor improvement but theres a great deal of missing info
look Ive been racing cars and building engines for 40 plus years and thats a great deal more to making a car faster that swapping heads alone, and theres FAR better heads available, so before you go swapping parts look over your goals and decide if those heads even if they add a few hp are worth the effort , or if you need to think thru the combo
yes Im well aware most of us are on very limited budget, that makes thinking thru the parts selection that much more important
http://www.wallaceracing.com/et-hp-mph.php
http://www.cprparts.com/HPcalculator.html
http://forum.grumpysperformance.com/...e+heads#p17024
http://forum.grumpysperformance.com/...hp?f=52&t=5078
http://forum.grumpysperformance.com/...php?f=52&t=401
http://forum.grumpysperformance.com/...php?f=52&t=727
http://forum.grumpysperformance.com/...php?f=52&t=796
Old Mar 15, 2012 | 07:38 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 342
thanks for the info grumpyvette. i'm running a 342 gear ratio. 16" goodyear tire. my car is peg leg so i have to get it rolling before i can give it full throttle. it has wheel spin until you reach 15mph.
i seem to loose my gettie up and go, in third gear. i'm tearing it down this weekend and installing the new heads. im going to roll the dice and hope for the best!
Old Mar 15, 2012 | 10:35 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
All this work and you havent even upgraded from an open diff?
Old Mar 15, 2012 | 11:45 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 342
The rearend was my next upgrade but i ran across these heads and couldnt turn them down.
Old Mar 15, 2012 | 01:30 PM
3rdgenmaro's Avatar
Car: 88 IROC
Glad it is on your list. You had me worried.
Old Mar 15, 2012 | 03:29 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I just visited grumpyvette's forum. That is some good stuff. I think I'll save it to my favorites list.
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
