CEL when braking
Old Mar 13, 2012 | 04:23 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
CEL when braking
When I'm cruising down the road and I either apply brakes or even just let off the gas, my CEL comes on for like 10-15 secs and then cuts back off, nothing important but just annoying
As always, thanks!
Old Mar 13, 2012 | 05:54 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: CEL when braking
Are there any codes present?
Old Mar 13, 2012 | 05:56 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
No, not when I scan it at the shop. Am I gonna have to scan it while driving?
Old Mar 13, 2012 | 06:26 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I have had occasional mystery CEL without any codes recorded
If engine appears to run right I wouldn't worry too much
Old Mar 13, 2012 | 06:29 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Ok, I guess I just didn't know if it was something with the brakes or something
Old Mar 13, 2012 | 06:59 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
As always, thanks!
95% that it's your O2 sensor readnig a bit rich/lean because of the motor's work load change when you let off the gas. My 84 would do that until I got the Carb built and tuned right for my new motor. Still occasionally does it but if you're not able to pull any codes, I wouldn't worry about it.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
