1988 v6 camaro
Old Mar 13, 2012 | 07:08 PM
Cebas(13)'s Avatar
Car: 1988 Camaro
Engine: 2.8 V6
1988 v6 camaro
i just had to replace the fuel pump in the camaro and now everytime i go to put gas in it it drips from the hose that connects to the tank. any advice please?
Old Mar 13, 2012 | 07:12 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 1988 v6 camaro
Which hose are you referring to? The fuel line hose, the fill tube (Where you put gas in), or the return line? There are several lines that connect to the tank. Also, little more about your car might be helpful as well as anything else that may have been done to it. Cheers!
Old Mar 13, 2012 | 07:20 PM
Cebas(13)'s Avatar
Car: 1988 Camaro
Engine: 2.8 V6
Re: 1988 v6 camaro
as far as i can tell the fill tube but ive adjusted it and tightened it but nothing. its a 1988 chevy camaro v6 2.8 auto tranny
EDIT: Also its a pain to reach the fill tube even with it lifted and advice there?
ktthecarguy
Jul 5, 2020 11:46 AM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
Billy Decker
Sep 4, 2015 03:46 PM
Linson
Aug 31, 2015 04:52 PM
