need help w/ bypassed pcv system
Car: 1992 Camaro RS
Engine: 305 5.0L TBI
a while ago i had my head gaskets replaced and while my mechanic was putting everything back together i asked if he could put on some chromes valve covers, so he got some edelbrock covers for a good price and put them on. of course the car ran better b/c it wasn't overheating anymore but i have noticed it idles a little rougher, then i noticed he bypassed the pcv system i guess b/c of the new valve covers. now their is a filter and oil fill cap on top of the driver side valve cover and nothing on the other side. can i replace the oil fill cap with a pcv to route it back in and keep the filter where its at or am i going to have to put a hole in the passenger side valve cover to put the filter?
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Re: need help w/ bypassed pcv system
you can just remove the air breather component on the valve cover and replace it a proper sized gromet and pcv valve and hook it up to a proper vaccum source. Check your vac lines while you are at it...maybe he left one out?
Car: 1992 Camaro RS
i don't need to put a breather going in anywhere(i only ask b/c in the haynes manual it shows a diagram w/ a breather/inlet on the opposite valve cover as the pcv valve)?
Ideally it would be preferable to have a vent on the opposing side to properly vent. But I still don't think that would be causing your sudden rough idle.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You should do a compression check. If you over heated your engine you could have weakened your rings on one or more cylinders and have a loss in compression.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Is not called Positive Crankcase Ventilation for nothing
Outside airflow through the engine removes fumes and passes them through the PCV valve to be burnt in engine
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
With those covers you'll have to either put a hole in the one for a PCV valve, or you'll have to live with the breather that coats your shiny chrome cover in oily residue.
The PCV valve provides a fairly significant portion of the idle air flow, so not too much surprise it idles differently after your "upgrade".
tyeo098
Nov 30, 2015 06:27 PM
