FUEL GUAGE SENDER DEAD AND GONE
Old Mar 14, 2012 | 09:44 PM
Blkened82's Avatar
Car: 1982 TRANS AM
Engine: 305 CFI (LU5)
Transmission: TH200C
Axle/Gears: 3.73 POSI
MY FUEL GUAGE SENDER IS IN ROUGH SHAPE (IT SAT IN SOME SUPER NASTY GASOLINE FOR YEARS - THINGS MELTED). A NEW ONE IS VERY EXPENSIVE AND A LITTLE HARD TO FIND. I COULD CLEAN OUT THE LINES, RUN NEW WIRING AND INSTALL A NEW PUMP NO PROBLEM, BUT THE ACTUAL GUAGE SENDER IS MISSING A CONTACT AND ARM FLOAT IS GONE. CAN I SWITCH IT OUT WITH SOMETHING FROM ANOTHER YEAR THAT IS NOT SO EXPENSIVE??
1982 TRANS AM 5.0L CFI
Old Mar 16, 2012 | 12:41 AM
82_Camaro's Avatar
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
Re: FUEL GUAGE SENDER DEAD AND GONE
my sender is bad to. let me know if you find one or find a different year. thanks
1982 Z28 Camaro 5.0L CFI Rebuild in process..
Old Apr 4, 2012 | 09:26 PM
Blkened82's Avatar
Car: 1982 TRANS AM
Had to go used. I found some GM parts websites that supposedly had new ones but after I completed the order, the next day I got an email stating that part has been discontinued (no $hit). I found several used ones available on car-part.com. Everything I have seen about this sender states that it was used in 1982-83 camaro/firebird with 2.5l & 5.0l fuel injected engines. I took the actual guage sender apart, cleaned the contacts with emory cloth and made sure resistance = 90ohms full and moved closer to zero when lowering to empty. Cleaned steel lines, ran new wiring, and installed new pump and hoses - looks great (going in the tank on monday).
Ghettobird52
Jul 5, 2024 11:18 PM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Irocohio
Aug 12, 2015 08:03 AM
