why am i idling like this? *video
Old Mar 26, 2012 | 02:46 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
http://youtu.be/YQhVLZWxYU4
whys my idle bouncing and kinda surging like this??
Old Mar 26, 2012 | 10:45 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: why am i idling like this? *video
think it could just use a tune up?
Old Mar 27, 2012 | 01:21 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
no one?
Old Mar 27, 2012 | 01:34 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
What all modifications do you have and when is the last time you changed the plugs, wires, cap, rotor, etc?
Old Mar 27, 2012 | 01:52 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
as far as the motor, its completely stock with the exception of headers/exhaust/cai..
all were changed about 15,000 miles ago
Old Mar 27, 2012 | 01:55 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
also, the last time i drove it, when i started it up, it kinda like died for a second then started right up..idk how to explain it but yeah
Old Apr 4, 2012 | 12:18 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
still idling like crap..its not the TPS and its not the MAF..now what?
Old Apr 4, 2012 | 05:09 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Check for vacuum leaks.
Old Apr 4, 2012 | 06:58 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Does it clear up past idle?
Old Apr 4, 2012 | 11:51 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
yeah i can get into it fine and it feels great, its just idle..
i just had all the rubber replaced not too long ago so i hope its not a vaccuum leak because that would mean its somewhere worse
Old Apr 5, 2012 | 01:07 AM
91'CamRS's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: 305 v8 TBI
Axle/Gears: Stock
Atleast yours isnt as bad as mine, or didnt look like it...from what ive learned check and see if theres any codes. I just started throwing parts at it trying to fix it from the symptoms i was having and no luck (replaced the MAP sensor, TPS, ICM, CTS, FP relay, had distributor checked, timing done, checked the vacuum lines) Then i checked the codes and came back with code 23 and 32 (MAT and EGR) i just replaced the MAT sensor today now going to take a look at the EGR when i have time. Best bet is to check those codes before you dump a bunch of time and money into it. Hope you can figure it out!
Old Apr 5, 2012 | 01:10 AM
91'CamRS's Avatar
Engine: 305 v8 TBI
Axle/Gears: Stock
As a side note mine is a 305 tbi so different from yours but you should still be able to get codes.
Old Apr 5, 2012 | 01:32 AM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
How many miles on the car?...my lower intake manifold gaskets just blew out at 157k. it idles crappy and lunges/studders on acceleration...hoping to get it fixed soon.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
