Knock in LB9
Old Mar 18, 2012 | 12:17 AM
dark0769's Avatar
Car: IROC
Engine: 5.7 HO
Transmission: Tremec TKO600
Axle/Gears: 4.10
Knock in LB9
I have a knock in my TPI LB9, now I have done some homework on this but still wonder what the heck i should do. Do I repair it which isnt a big deal or do i go crate as I am still trying to keep cost down. I thought of the GM crate as I work at a gm dealership and can get the engine cheaper but at the same time the heads dont work with tpi system and yes I realize i could go but the edelbrock intake but then again more cost. I tossed the idea of using the LB9 heads with the 350 ho engine but the question i have is will it hurt me or will i gain power. If I go 350 ho then I must change a few things which is fine but man i would would like to keep my cost in mind as I realize injectors and prom and intake and a couple of other things would have to be changed which adds in cost and I would like to keep it down. Wish I could just buy the LB9 but looks like the 305 small block is a thing of the past. I could just get a 350 small block crate engine which is fine but what crate engine bolts to the tpi but still maintains the power aspect. Currently it`s a 305 tpi 1989 with a 5 speed manual set-up. Thanks for any input!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
