kickdown bracket alignment?
Old Mar 18, 2012 | 06:39 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i got a 355 sbc and 700r4 trans. it shifts short and sluggish shifts, and over revs on 3rd gear under hard acceleration. now i got the edelbrock bracket that bolts to the manifold. i installed it and the cable slider doesnt slide forward when the gas is pressed. i pushed it back til it stop and mashed the pedal and the slider never came out. i grabbed a pair of pliers and tried to pull it farther but its maxed out. am i missing something?
Old Mar 19, 2012 | 10:16 AM
Engine: 355
Re: kickdown bracket alignment?
nobody has had this issue?
Old Mar 19, 2012 | 12:55 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Carb, TBI, TPI--
What was on it, what's on now?
Did you remove the TV cable at any point?
Geometry corrector may be what you need.
Old Mar 19, 2012 | 02:05 PM
Engine: 355
carb, put new intake on it and did it per gm directions on cable. i have the geometry corrector on the carb already. im not sure if its the cable or the governor
Old Mar 19, 2012 | 08:19 PM
Car: '87 Camaro
Have you been to
tvmadeez.com
They tell how to test pressure.
Old Mar 19, 2012 | 11:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Is the Edelbrock bracket you have for a 700R4 or a TH350?
Old Mar 20, 2012 | 10:29 AM
Engine: 355
its for the 700r4. EDL-8030. yes ive been to tvmadeeze, but it still doesnt ratchet out.
Old Mar 20, 2012 | 11:09 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Can you post a pic of how you have it set up?
Old Mar 20, 2012 | 02:03 PM
Engine: 355
yes ill take a pic of the carb and bracket as soon as im home from work this evening
Old Mar 20, 2012 | 03:28 PM
Engine: 355
ok i got home and i pushed sown on the tv cable and it will almost touch the intake when pushing the cable itself down. is it supposed to be tight when its at idle and wot or just wot?
Old Mar 20, 2012 | 04:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not "tight" at idle per se, but without slack.
Old Mar 20, 2012 | 05:23 PM
Engine: 355
ok i got it shifting in all gears now but there really soft do i gotta go toward firewall a little more? its not reving out but there horribly soft
Ed1LE
Sep 30, 2018 09:14 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
